Ahh, so basically since the controller doesn't have an OFF position, I won't be able to turn them off entirely? Not the solution I was looking...
Bummer, I checked the controller packaging and there's nothing more specwise listed there. Considering what I went through to actually find 6 of...
I am currently getting ready to rebuild a machine and have a question concerning fans/LED's/fan controllers. I have finally found enough...
That is very slick indeed.
Thanks GoodBytes and EnglishLion, those are premium examples of what I am looking for when I rebuild the main rig this holiday. Excellent setups...
Howdy BT folks! Been checking out your fine site here, some very talented individuals out there for sure. Figured I'd post some of my own...
I'd suggest turning off automatic restart for the BSOD so you can actually log what the error is. That way you can actually see what the BSOD...
Just did some snooping about.. Here is the 250 GB SATA Version. From a modding point of view, these little buggers could have some potential in...
If it's what I think it is, it's a 1.8" mini hard drive. I have one in my MusicXDrive Pro. Have to install the thing internally on that XDrive,...
