Dual x16 workstation boards shouldn't be a problem. The x58 is basically a single processor "Thurley" board (The codename for the platform which...
The server/DP workstation boards should be out soon. I can't remember what the chipset will be called though. The hardware involved is very...
Is the CPU fan connected to the 4 pin CPU fan header? If so, the system could be throttling it back, but the OEM stuff I have seen is pretty loud...
They *might* be upgradable via firmware like some SD based devices going from 1gig to more than 1 gig SD support But it would all depend on the...
Do you have any other details like chipset, CPU socket etc? Are these 'recycled' OEM machines like a little computer store that sells old Dells?...
There any numbers at the corners of the screen (like a 2 digit number)? Otherwise, the board should have an LED or LCD display that displays 'post...
USB explained: USB 1.0 is low speed USB. USB 1.1 is full speed. USB 2.0 is hi speed, USB 3.0 is super speed. USB 1.0/1.1 host controllers are...
It can help simplify the line by using the code name combined with the front side bus speed, clock speed, and cache size to help rate the CPUs....
Well, the one last thing you can try is to view devices by connection in the device manager, go to ACPI (or something like that) PC, then PCI bus,...
Let me backpeddal on my reinstall comment a bit. IT is doable in some cases, but some drivers need to have the generic version of them installed...
What exactly is this, an MP3 player, or a USB sound card? If it's an MP3 player (which it does look like), it is very unusual for them not to be...
Just to get this strait, you took a drive with an installed OS from a asystem based on the P35 chipset, and just dropped it into a system with an...
Those x4 cables will work with SATA fine. This is from the mainboard of a server I get to play with: [img] It is clearly labeled SATA 1_4 for...
I'm not after the pinout. What I am after is the supplies to make what amounts to a coupler, and a patch cable. I would like one to have one end...
I'll agree on this, trying to use a computer on a couch without some sort of table you can bring close to yourself is no fun. Concerning the...
Can you set the fan speed in the BIOS when on the 4 pin header? HHM shoud have control of it on the 4 pin header.
I have heard some rumors about Atom CPUs being paired with other Intel chipsets. But these are just rumors, and there is no time frame involved....
The screen is visible from all seats in the car, so it's not just for the driver. On top of that, I hate to cut the ability out of the system. I...
Does anyone know what I need to search for to find the 4 conductor 3.5mm 'stuff' that carries audio and video? Specifically, I'm dealing with a...
The quads don't have as aggressive power management as some other Intel CPUs. If you switch to a 45nm part that would help some. You might be able...
