Thanks, what is the minimum I need to run Sims well?
Oh, and it needs to be "pretty" don't ask me why...
Hi everyone, I hope you are all good! My partner's laptop has gone to heaven, and I have about £400 (absolute max) to spend on one. She need it...
The dvd drive are all on irc 14 and no other things use that irc. Still perplexing. My DVD drive will only burn at 2.4x speed.
..and drive read was actually .22mb p/s
I use performance test by passmark. The cd was clean with no scratches. Steve
Thanks for your time over this. I am still not sure what you mean regarding resources. Update. Last night for no reason the dvd drives...
is there a resources tab in the bios?
yes previously they were fine. This system is quite old
I am not really sure as I have a confusing bios screen. I have unplugged one dvd drive so I have 2 sata drives in Raid forced generation 1 and...
I dont get it. Is there any way to fix this? I dont know how to te resources. I have ACPI enabled. Cannot find AHCI in bios. Any help...
I dont have a spare cable. checking AHCI My computer properties says I am using physical address extension too.
The error in device manager says: This device cannot find enough free resources that it can use. (Code 12) If you want to use this device,...
Hi I am not sure if this is hardware or software related. I have the system in my setup and I have had it for 3/4 years. I upgraded the...
Hi My GPU uses a 16x pci express slot. Can I disable the normal pci slots in the bios to save memory? Thx Steve
Sorry for spam... Here is the "everything you need to know to configure media server guide":...
The beta version is fine by the way: http://code.google.com/p/ps3mediaserver/downloads/list
I have another solution that works fine for me. Download pLaystation Media Server, and stream all your media through your pc to your PS3. You will...
Thanks again. I had to reset the CMOS using the jumper about 4 times. Installed a earlier bios. The initial "stock" speed to the cpu was still...
Have moved the bios to original bios. The pc is still stuck at 1.8ghz with an fsb or just 200 mhz. Can anyone help please!!!
