Denki are the cheapest compare to others and still pretty good, as long as you gonna keep them on decent speed
plus SSD are so expensive taht no point buying it now - the lastest can perfrom above 100/1200MB/s speed, which is pretty good,but still - wallet...
funny mod:) I like it:)
Consider DS2R mobo
I tested Noctuas with loons - Noctuas are better. Flex are also good
New week starting... any updates?
looking good so far.. any updates?
nice colors... good idea with the shape...
You did incredible job painting it... have you updated it lately?
nice flames... good job on cutting them..
Dell.. or Benq
I cannot vote here, what is the rule for voting on this poll here?
it will cost about 500, so two cheap GTSs would be about 420-440. Still cheaper.. then buy wc blocks for them:)
my e8500 its pretty ok, sometimes motherboard can slow you down with oc... mine is not taht great...:( EDIT: I have matx mobo.. they not so great...
so 8800GTS 512 should be ok for 1920x1200... OC to 800MHz and you 'll be fine...:) EDIT: I tried my friends gts512, great card.. enough... but...
DDC, 10W - you can always do a mod and make it 18W... Or you can buy any pump and use fan controller to control the speed...
http://www.overclockers.co.uk/showproduct.php?prodid=WC-028-SW&groupid=701&catid=193&subcat=1038
I have a logitech ultraX, great keyboard...
CPUtemp, Everest, fanspeed...
it great but too expensive to buy - better is to get two 8800GTS and run them in sli...
