Nope, They do it here, Too. :-S My roomate had his go from US$1,000 to US$5,000 with out him asking or wanting it. Credit Card companies are just...
A Dremel, Tape, Glue, Drill, tin-snips, exacto knife, scroll saw, drill press, pliers, screw drivers, a hammer and alot of Band-Aids
If you want forearms, stay away from machines is my advice. Free weights will help build up all the stabalizer muscles where as machines tend to...
I'm a college athlete, i think my cardio is up to par ;-)
Mhm, yep, thats about right. But more! :-) Make it look like the ooze off of TMNT! then you will be set.
i expected a thread about wrestling :-(. oh well, as long as we are on the subject.... I wrestle :-). i also lift, can't do all the stuff the guy...
is there some way you could make it look like there is a glowing green goo flowing out of all the seals and cracks? maybe paint a big crack on the...
I would say use a scroll saw, but only if it is a higher end model. However you cut it, you will have better luck if you run a piece of masking...
grill 2 looks alot better
Red X's of doom :( :waah:
There is a little bike group in my town. they all have normal bikes and these, and for some reason they always ride these. they are all almost...
This thread is soooooo far from anything even remotely mod-related. Spelling Sucks, it's so much harder than it should be. hooked on fonicks...
Mines the 4th! :-) 4/4/1985. Im 19 now, and all the 15,16 and 17 year olds are twice as smart as me! (with computers)
too easy, 10/10 2x
Did you Glue the top window in or is it help in with brackets or some other way? Nice Job so far.
I am a student now and makeing $US12 an hour. This adds up to about 18.5K after taxes. It all goes to saveings now, and i only work for 3 months....
Canon makes the best digital cameras, in my opinion. The pictures come out great with little effort and most importantly the features on the...
I think the UK is still one up on america on this one. They may link terrorism and piracy, but in America you get down right accused of BEING a...
I had a T3 line at school! a DSL at work and 56K at home that runs like a 28.8. I'm thinking of suicide.
I Did, the site has the plastic part but not the clamp down pins anymore. Thanks tho! :thumb: I need to get the Clamp pins (male and female)...
