The project isn't dead. I've done some other work to it which I haven't posted yet. But right now I am fairly busy with stuff at TTL and...
A lot of power supplies are pretty much Fortron PSUs with someone elses name on them. Which Zalman do you have? I have the 400b. As for the...
Don't want to talk about it publicly. I sent you a PM. Beware with that thought. The Soyo Raptor, which has a 120 mm fan, is anything but...
I have worked with a SilenX PSU as well as a Zalman PSU. SilenX and Ahanix are two very shady companies and I personally don't trust them or...
The processor only generates heat when the computer is on. Because it is generating heat, it needs some way (a heatsink) to remove the heat....
Heh, I have similar plans for the side panel of my case, but my scoops will be completely custom. Fabricating them out of fiberglass, like the...
Rubbing compounds give a much smoother finish than just sandpaper. Once you have sanded a surface down to 2000 grit, most rubbing compounds go to...
I mod for me, but I also mod for the public. To me, modding a computer is very similar to restoring a classic car (besides the obvious custom vs....
You mean you like it because it is a beautiful work of art in progress, right? Right??? *sniffle* Today I did the majority of the...
it's not the exact IE logo. There is a stripe down the middle and the warped halo which differentiate it. I guess they thought the logo was cool...
Nice idea with the power switch. Can't wait to see how it comes out.
Damn right! I have fans! BWAHAHA Anyway, thanks for the support :D Today I am working on LOTs more fiberglass stuff. Two more pieces, and...
Ok, finally time for another update! Sorry for the delay. All the top cooling compartment pieces are completely painted and dry so I...
Probably because the fans have to fit in with the design. Bigger fans wouldn't work out, although he does have bigger fans in other places.
Even if the "rondel" arn't washers, I'm sure washers would be a fine substitute :P
The mobo should be fine there. As long as you don't have any pets or kids that might poke at it. I have computers sitting on desks and tables...
I've followed your first HL case, and now this one. I am in awe at every picture you post, every idea you have, and that one picture, of the...
Well, I wasn't a big fan of the movie... at all... but this mod kicks so much ass. Great job! Great great job!
The brake has a hinge in the middle. You place the metal sheet on top of the hinged part and place a giant metal bar on one side of the hinge....
From the looks of it, the back panel that has the tubes coming out isn't glued onto the container. He probably still needs to cut the holes but...
