Solid diamond; good heat transfer.
I bought LED's from the same guy. Those are for working with 5v, I believe the red wire on your molex. There's lots of guides on how to use them...
Awesome! Good luck.
It was really really easy to make it. You just need: LEDs Resistors (470 if your working with 12v, like I did) PSU (preferably one that isnt...
Hands down the coolest symbol ever is the Marathon symbol. You can see it here: [IMG]...
It's way, way way to small.
It's nice to know im now the only Marathon fanatic out there. I still play Marathon on my PC fairly frequently. Never played Halo though. Keep up...
Am I the only one who recognizes the Marathon logos? Best game(s) ever!!!
Theres only 1 LED per 'cluster' the wire is just bare steel wire I have wrapped around plastic pushpins that are stuck into the wall. I put up a...
*drool*
Argh I swear you people just want to see my messy room :D. I bought 50 5mm 6000mcd LED's for 9.99 with resistors off some guy in hong kong on...
I just got one of those sound activated modules that control the cold cathodes and used it to control the LED strings I put up. I can change the...
A bag of LEDs, some wire, a sound activation module and ALOT of boredom led to this travesty... http://www.sfmwonline.com/files/blinky.mov
