Wow, turnout's been like the British election... :D Hmm, well it looks like i'll be going for the centurion 5 then, the antec looks nice, but...
I love that eye of RA, if you can get a golden shimmer around the frame like the picture suggests it would look amazing. Gotta try and do one...
I'm hoping to build a new computer based on the dothan core soon, and want a nice case to go with it. I'll probably mod it, but i want something...
I will try that list, thanks. I tried the 5:6 timing and i still got a boot up error, but hopefully the other settings will work too. Thanks...
I have an msi K7N2 Delta, 400fsb edition and an nforce2 chipset. I am trying to overclock my amd athlon xp2800+ to 3000 or 3200 speeds. I have a...
Right, i'll change it to a folder restricted array then. Can anyone help me with the first problem of the link being reset? I could specify...
Damn, i thought i was clear using the "..\" block script. Would i be ok if i were to block :\ commands too? Or are there other ways to access...
Hi guys, i have a feature on my site i need, but can't code, can anyone help? http://quactaur.dnsalias.com/main.php is the page i wan't to...
If you really are gonna stick with aol, ring em up and act like your going to cancel. When we did this, they said they'd give us aol broadband for...
Hi guys, im trying to setup port forwarding for my system and i was wondering if you could help? I am using two pcs at the moment, one, my home...
Is there a program you can use to encrpyt text files through text scrambling? I want one that uses a public key, not a ROT rotation one. Is...
thanks a lot, now, any ideas how to get this slipped onto a disk?
Does anyone know how to change or add information to the system properties box on Windows xp? If you buy a non dsg/oem copy of windows, when...
I'll change the sig now, The thing is, all the files on my site are set up like this: _private folder www/ folder (this is where the web...
my password file is in a _private folder which is password protected isnt that secure?
thanks a lot thats what i was after
What is the php tag that you use to link it with sites? the tag that, after inserted allows you to do links like...
No, its not the psu, i shorted it and it works, it seems my mobo is dead :duh: doesnt matter, i still have a waranty and can exchange it
I have a coolermaster jet7+ a big copper heatsink witha blower, its probably my poor cable management, placement of case or both, but wiht a...
i've tried, nothings happening. All my other cards (pci, ram, etc) work, so i guess my processors safe i'm taking it to our hardware dealer...
