Sorry but CNC (Computer Numerical Control) is the whay in witch the machine is controled, the cnc controls the machine ie a milling machine or a lathe
Very good work :dremel: :rock: I think he means the clamps on the pipes lol, not the bends thay are pipe clamps or hose clamps.
Iv just got a reply from creative giving me this link to the cable i need, dont know why i couldent find it before. anyway its out of stock...
Ive just found this Page where it explans the cable layout, but no link to where i can get one so ive orderd the components from maplins needed to...
yes i see. but i cant find them anywhere thay seam to only come with the 7.1 speakers if i could get some of these speakers i could mod them to...
I have Audigy2 ZS and VideoLogic ZXR-750 speakers, because of the way the Audigy2 ZS outputs the 7.1 ie on 3 jack plugs insted of 4 i can only...
Thay are about the same price in the UK around £567.63 ( http://store.over-clock.com/Refrigeration.html ) and i thought that Extreme Cooling...
Did you consider going for a Prometeia 2 (Formerly known as Mach II GT). from the reviews iv read thay give lower temps. have a look at this...
this is sods law ive just found this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=1246&item=6707422314&rd=1 on ebay it would have been...
so you dont need the data lines and the power lines switched seperatly then? when you switch from one to the other dus an anoying popup nere the...
ConKbot of Doom iv desided to go whith the rotary switches 4 pole 3 way that kbn sujested then i only need two. but im now going for an all in one...
one more thing i thought that you had to trick the computer that its not Connected to into thinking it is. have you tryed it out on two computers yet?
ConKbot of Doom i have worked out what you ment yesterday my brain wasent working last nigh. thanks for the help. iv found some 4PDT but dont...
do you know the part number?
iv just posed in your thread switching USB devices
could you post the circuit diagram for that. ive got a wireless keyboard and mouse and its got just one usb plug so this is ideal for what i...
my speakers only have analog inputs i did read about using laching relays. but am not 100% shore what you mean. i now what 4PDT means but not how...
Iv go a problem ive only got one set of 7.1 speakers but have two computers and a stand alone dvd player, ive looked into audio switchers but cant...
One thing i notised with mine is if the memory timings are set to auto then it seams to be alot slower
I think its an old (Edit not ATX but AT) motherboard power conecter or floppy power conecter but the pic is to bleerd to be 100%, how meny wirs...
