Simple poll - which one for a cheap setup Gigabyte ma790fx Athlon II 630 Arctic cooler v2 Asus 3870x2 Could get either near the £40 mark...
Hi When measuring resistors should it be exactly what it is rated at ? EG I have a 47k resisor measuring at 51k - is this faulty ? And I...
Just took my DVD player apart as was playing up and discovered it has a standard IDE drive in it. Normal for DVD players BUT there is only the...
Why oh why is it that 90% of the time I cannot even see the bargain bin in the list. Go to another forum come back then it shows ?
Is it easy to remove the EL backlight from my LCD ? What can I use instead - LEDs ? I am fed up of looking for the correct spec inverter so...
My LCD needs -14V I have connected it to the -12V supply and even with the contrast pot turn fully up I can only just see that the display is on....
Just wondering if I could use the car adaptor to power the PSOne and 2 of the official Sony LCD screens instead of the one screen it is intended...
The fan on my GF3Ti200 has stopped working. I have tried another fan but it looks like the outputs on the card have stopped working. Is it safe...
Wondering how to get -14V from a standard molex connector ? I did have an IC that gave me -12V from +12V supply but this gave a very dim...
I have wired up the power only to my Toshiba graphic LCD and get nothing on the display. Turning the contrast pot I can see the whole screen...
HI Does anyone know where I can source one of the following http://www.jkllamps.com/briefs/NDL202.pdf I have looked on digikey but they...
9600XT now or save up some more for a 9800PRO - simple as that really. Oh and I am running a Ti4200 at the moment and play mainly FPS's
Does anyone know if its possible to alter the output frequency of an EL inverter. I picked up a nice cheap one not knowing what specs it was....
I have read the FAQs and the links but was just wondering which is considered to be the best, easiest to use free schematic, PCB & stripboard...
Which way are LEDs measured. Length or diameter ? Thanks.
Sorry about the title - couldn't think how else to describe it. I am wondering how LEDs would shine through a piece of plexi if I bent it. I...
My nice new 128x128 graphic LCD can be wired to give 2 different font sizes. 6x8 dots and 8x8 dots - which is the standard to use or does it...
What is the MCD rating on LEDs- I have seen them ranging from 1,000 up to 6,000 and I don't know what this means and which LEDs to buy.
Dumb noob question for you all Does this multimeter measure frequency ? [IMG]
Does this have to be wired or can I ignore this pin altogether.
