I got a new pump, a fountain one, it's specd: head 90cm, 650l/h the output has got a 9mm ID, the same ID as 1/2" barbs so that should be ok(from...
If I have a waterblock with 3 barbs, 1 input(middle), 2 outputs(sides) could i run different branches from each of the outputs? like, from the...
well, i thought i'd post this although maybe it wouldn't quite qualify as a mod by some people standards and it s not actually mine because i did...
anyone knows if it s ok to use an electric fuel pump from a car? they don t have high flow but they do have high pressure 50 psi or...
http://www.themeatrix.com/ it has a nice chick in it too :lol:
...well...the spinning head doesn t seem to be properly aligned and straight... for instance when i put a bit in like a drill bit and start...
hello, not sure if it s the right forum, but I ain t getting emails when someone replys on the forums? is it just me??? /edit my mails...
hy, anyone can give me some info on how i could dim or brighten a led based on variable input voltage? the led will probably have a stable power...
