I bought Twinmos and it doesn't work... So www.tekheads.co.uk offered me to change it to adata... I thought Adata was even worse then twinmos......
[IMG] [IMG] [IMG] Is the hd ****ed, or can it be fixed, 1 week old...
I have just recived my LCD 5" (voyager 5). [IMG] This connection have to be changes so it fits the power from my PSU molex connector... How??
The backdorr of a car is often held up by one or two things that pushes the door up.. Whats this thing called? Where can I buy it?
Parameter Min Typ Max Unit Luminous Intensity 4308 5600 6200 mcd Viewing Angle...
Are there really no webshops in the UK that sells nice switchs?? [IMG] This is a picure of the volume switch on my dvd-player. I would...
[IMG] Im trying to mod new power switch etc at my up commin case... What switches will be best to use ?? Im going to mod a 5 mm thick...
Isn't this very cheap products? http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X3Jldmlld3M=&product_uid=51686 12"...
I have read through most of the threads about graphical LCDs on this forum. What I found out: You need: LCD screen as : The pictures i...
Wanna buy a LCD like this . It can be controlled thru the prallell port. But where can I buy it, and what brand should I use?
Im going to make a led controll unit.... Four small switches on/off. That controlls from 4 to 12 blue / red leds.. My questions are:...
I``m going to buy a new computer. And someone talled me that a 250W CPU wasn`t enough for my new AMD 64 32+++ system. And that I should...
What its important for me and anyone else is sound. I`ve asked a bit around and some say that their Eheim pumps makes some sound. (Is there any...
Is it possible to modd it in a bok with sound proof meterial, or will the pump over heat or will the water cool it down?
Where to find blueprints for Blue led 5V? I had a drawing yeasterday, but can `t find it..
Will my watercooling kit still work with the new socket 64 bit AMD? Im going to upgrade my computer later this year, but want to buy a...
I live in UK, so mainly uk web auctions and so please. I want to buy a used watercooling kit, where is the best place? And one more q. how...
240mm * 120 mm radiator be enough to use with a 50-120 W peltier? And will a peltier on the AGP card be needed? What type of Watercooling...
If there are something that I have forgotten tell me. Some Ideas on changes tell me. [IMG]
How much does aluminium weigh?
