Man if you have a P3 550 you could have a sweet little router/file server linux box. Slackware 10, 2 NICs, Samba, IPTables, a couple of commands...
coil - I would use some type of switch like that but it's an AT style power supply switch. It clicks in and locks, and then you unclick it and it...
Project OutPost - Part III Hey guys, I have a little update on the project. Sorry about some of the pictures, I had to take them in 10 minutes in...
As far as the linux distro I have decided to use IPCop v.1.3.0 for now. I would like to get a small install of Slackware 10 and get familiar with...
Haha, I knew I'd get a comment about the mesh, my roommates said the exact same thing. I was trying to get a little mesh theme going by using it...
Project OutPost - Part II Time for an update. I started cutting last night and it was unreal how loud the sound was reverberating through the...
Hey guys, I'm a long time reader of Bit-Tech and a first time log poster so go easy on me! Concept So I have wanted to post a project log on...
Hey guys, I need some help.. I have a pair of these speakers my roommate bought and we want to run them through the TV to get some more sound. I...
My first FPS was Doom. I remember installing it from 2 floppy disks onto my 486/DX33 with 4mb of RAM. Doom2 was a killer, having to edit your...
I believe that was in the American Pie movie. Anyone know this one? Guy1: So what's with the nurse's uniform? Guy2: These are O.R. scrubs....
Heck yeah, go Raiders! I'm currently a student at Tech and I was really suprised to see this project in the project logs! Curious to see how this...
Forget the caster like wheels, use a dolly hack it up and weld that sucker to the back end! [IMG] Those big rubber wheels will make all...
whoo, that is definitely gonna be a blooooo computer. Take that sucker and turn it into a linux box! It just screams Slackware :D
Here is my entry Simply Linux Just like the title says, simply linux. This is one you'll go back to over and over again... trust me.
Dude check out this site, one of the better ones I've found. http://jetblackz.cjb.net/ Someone needs to sticky that URL (Hint hint RIT) because...
Haha, no I don't do any SETI crunching. I just have my main workstation (P4 3.2ghz) and my gaming server (AMD 2.2ghz), linux box (dual P!!! 750)...
Thanks for the tip, I'm trying to catch all of the hot air and suck it out because it's just too hot in my room. I might try and put a fan in each...
Hey guys, I need some help cooling the rack of computers that are in my dorm room. My idea to to take or construct a hood like you would see above...
papeniglio, thanks for the heads up! I got it in mysql eventually. I ended cutting up the install script and doing it in a few pieces to get...
Sam, in your smb.conf make sure that you have uncommented "encrypted passwords=yes" and also be sure to add yourself as a user in samba by...
