after getting the pass-throughs installed for the upper pedestal, it turned out to be quite easy to stick with hard tubing for the rest of the...
Just a quick update on progress... I've decided to use soft tubing on the back side and in the radiator pedestal. Although I could have made it...
I've made some good progress since the last update! First batch of fittings have arrived: [IMG] [IMG] [IMG] [IMG] [IMG] Started...
Now that I have this thread basically caught up with progress so far, a bit more on the plan for the build. First the NAS side of the chassis:...
Vertical PCI slot openings cut and fitted into chassis: [IMG] [IMG] With one of the GTX 970's mounted: [IMG] Stock heatsinks removed from...
Some more parts deliveries... Intel Core i7-6900K and 128 GB of G.Skill DDR4 3200 memory: [IMG] Fans, fans and more fans (actually ordered...
Fabrication - take 1 Made up a new center divider from sheet metal to cover all the holes in the back panel: [IMG] It actually came out...
Some new parts arrived: ASUS X99-E WS Motherboard: [IMG] Icy Dock 3.5" HDD hot-swap drive bays: [IMG] [IMG] APC 1500 kVA UPS and dual...
It's been years since I've posted anything on the forum, but felt this project would make for a good build log thread. I'm actually about 2 weeks...
It's actually a RAID 5 array, so the total available size IS just short of 1TB, but I'm going to add a 5th 250GB drive to increse the available...
My mobo uses slots 1 & 2 for dual chan and 1 & 3 for single chan, but thanks anyway. Bill
I got them from www.cyberguys.com they have alot of neat stuff, and their LCD mounts were just what I was looking for. I actually haven't...
Hey guys, just a quick update for everyone in the US. DC Data the company that Macro purchased the 3D film from ships to the US. I ordered 3...
Wow, it's been a long time since i've posted an update here, but hopefully this is worth the wait..... My LCD monitor mounts showed up and were...
thanks. well atleast i don't have to worry about fixing anything for firefox. I am working on shrinking the main movie a bit more though. It was...
ellism, thanks for the response. I only tested with IE, NN, and Opera. I will look into a workaround for Firefox, but it doesn't make sense since...
Thanks for the honest critiques guys, I really do appreciate it. Anyway, I fixed the preloader to function correctly and I changed the Intro...
so far the ideas sound great... keep em coming... I have made some decisions though, between the cost of the perspex needed and all the...
Well, I was sitting here bored the other night and had a thought..... So many people put their talent, time, and money into modding their...
Basically, water by itself is the best liquid for cooling, the addatives are only there to prevent corrosion and kill bacteria. Anything that you...
