thats the best thing ive heard all day. i dont know what it means, but, its super dooper!
that zenith data systems computer was my FIRST computer. it had a 386 in it and about FOUR megs of ram! i loved it.
this exact same thing happened to me in my room. it seems that one plug in one outlet worked and the rest only partally worked. i had a dsl modem...
i use an old soundblaster 16 pci and a hercules sound card in two of my pci slots. i have three sound cards in my computer if you include...
i heard somewhere that athlon 64 wont work with the btx specs, i think it has something to do with the on chip memory controller being to far from...
yeasterday someone asked me to go over to there house and see whats wrong with their computer. i went over and updated all the software on it and...
jsut a few days ago i blew up my SECOND a7n266-vm. i was testing a freinds power supply on it and when i turned the computer on the headphones...
iirc it is a 72 pin simm, they had to be installed is pairs because they were 32 bit so we needed two of them to adress 64 bits at the same time....
i get about 1.2-1.3 Mbps down and my downlaods are about 150-160 KBps.
well a few months ago the fan on my geforce2 gts started to crap out. i decided to take it off and while i was at it i would put the northbrige...
if you have resedental dsl at 768/128 or 1500/128 you can call them and ask. i did and they say ittl be upgraded by tuesday.
seems to me that the mains adapter is broken, can you test the output from the adapter? id buy it, but i live in the us.
my friend has this same problem w/ his usb. i pluged in a 5v led into a port and it blinked. all the usb connectors physically attached to his...
why not try, plugging a normal vga monitor in the compaq and see if it works. aslo try using an old pci graphics in the slot in the compaq and...
the worsty i have been burned was w/ one of thoose pen irons. the tip hit the skin at the base of my thumb. it hurt for a minute or two, but...
i remember when i first saw zdtv, it was on channel 7 here. we had it for a month before i saw all these computers on it and found out it was a...
i handent heard of g4 either. we just got digital cable and to my suprise, they had g4, so tomorrow ill have G4TechTV YAY! :yawn: to be...
well i remember when the least expensive optical mouse was 40 dollars, now you can get one for about 10. it also seems to me that a ball mouse...
busted caps? :D
one time i was modding the led on my mouse, changing it to a blue one. i messed up and somehow it was flashing really fast, about thirty times a...
