cogitoergosum: This was just a scenario, I need a bit like this for other scenarios as well! (being able to "remove" metal like that, but not...
I'm kind of "new" to the dremel and was wondering what bit I would use for a scenario like this. Lets say... I need to drill a 5mm hole, but...
Nope. It doesnt work while off or on! Another reason why I dont think anything is wrong with my keyboard physically is that I just read on a...
Today all of a sudden both of my CTRL keys and my CAPS LOCK key stopped working. Every other key works fine, I didnt spill anything on the...
I just tested it again(the new ram) with 5/4 cpu/ram ratio and it didnt even run stable at 412/329 ARGH! I know my motherboard can do better...
This is the setup I had: SN41G2 2500+(locked) 9600pro 2x256 generic pc2100 SB live With this I was able to stably run at 2.31ghz (11x210)....
xp2500+(locked) @ 2.31ghz[11x210] stable (SN41G2 shuttle with a few mods like grill cut out, new fan etc..) I've gotten it up to about 2.38ghz...
I've OC'd my 2500+ to 199fsb(2.19ghz) But... I wanna go higher :) Heat hasnt been a problem for me at all... I cut out the back grill and...
I have a SN41G2 right now, and the mobo is limited to 200fsb(that's the max you can OC in bios) I heard the SN45G's mobo can go over 200fsb in...
Is there any way to buy a new mobo for my sn41g2 case? I dont buy a complete new shuttle to be able to OC higher. And I DO wanna stay with the...
Mad Bomber: I'm pretty sure it has nothign to do with my memory. No matter what memory I have in there, the mobo limits the max FSB to 200. (a...
bump!
In bios my mobo doesnt let me go over 200fsb. I was wondering if this is a motherboard limitation or a bios limitation(meaning a new bios would...
How would i go about getting aluminum to a mirror finish? What grit sandpaper? Wet or dry sandpaper? Any other tips or tricks? I've seen this...
I knew someone would say it :)
Is there such thing as a metric or US size for nuts? If so, the size you gave me is that US or metric? And if it's metric would you mind giving it...
What size nut do I need for a mobo standoff? (those bronze things, what size nut will fit on the screw part of it?)
I swear I'm an idiot, LOL :) I just tested it with anohter fan and it worked fine... i guess the fan i tested it with at first was messed up or...
No idea on the switches, I bought htem half a year back when I still lived in Austria. All I know is they cost 4euros a piece and have 2 poles...
Yep, checked right before I posted the thread to save me from the humiliation ;)
