Have had some soldering iron incidents, some of which even left a cavity for a few days, but I don't remember any of them hurting that much....
It was on the plastic. (Mark my words :hip: ) After closer inspection, I was convinced it was "normal plastic", so I whipped out my Isopropyl...
I've just bought a new case sold under the Lepont label, here in Norway at least. It's made on a factory called Super Flower, and here you can see...
someone said this earlier, but no one responded to it. Wouldn't simply soldering a capacitor in series with led do the trick? No wait... it...
I know nothing as a casemodder, but my sense of logics tells me that you'd get better airflow with 2 in and 2 out. You're right about the fact...
Where do you find new versions of mbm? Via Hardware Monitor System V2.04 is very boring...
I don't think that the HDD-led pulsates when it seems to be constantly on, at least from what I can make of this article. All I can think of is...
I have considered those spikes, since I have seen that all the 1337-d00dz has 'em, but what do they do, excactly?
You (Fly) sound like you know your stuff, so I have a question for you: Currently my sub is facing the wall, about 5 cm away from it. How did it...
But where is the darn 'putar? Please don't tell me it is the entire 19" rack of to the left?
You still get those white lines around the screen tho...
The thermometer is of the infrared kind. On all the other processors but the first one you can see the read beam that the thermometer shines on...
most of the time they do, but apparently they are all on strike, or was it lunch, or whatever... Ok so I'm a limp-dick looroll who can't be...
That about you shouldn't look right at a UV light-source has got to do with the fact that you can't see the light, so the eye can't judge how...
Macroman: Have you got a data-sheet for that mic502-thingie? Can't seem to find it here in Norway, so I'm generally looking for something similar...
What is that supposed to mean? Seems to me that the only problem here is that whoever made the graphics, had his contrast turned down a bit,...
Just tried it, and it's very dim, and hard to get an even lighting. Didn't notice anything of it getting dimmer, but then again, I only tried it...
32 bit. The top-left one is definately there. For some reason I don't have Photoshop installed, so I can't color-pick them... When I look...
As well, the Bit-Tech logo (top left) on the frontpage has a slightly different background-color, than the site's bg-color... It's a bit lighter....
then it won't work on my 3310... But I can by some filter at a good photography store someone said?
