agree to you all.. Steam is a great. Those guys from Value know what gamers like. They build gaming industry with gamers, not against them....
Until now, I have been using the Acronis True Image for a while. It definitely helps out a lot. I truely suggest it to anyone. p.s. Thanks...
Hi ! I am looking for a program that could replace Norton Ghost. I needed a Recovery program that could recover your system after software...
I bought the G5 few weeks ago after a lot of research. I found that it is one of the best gaming mouses out there. You might can get a nice deal...
I re-create the array using settings of : stripping Block : 32K Boot : Yes now it...
Hi everyone !!.. recently I got a nforce 5 motherboard running Raid 0 with two 300GB SATA Harddrives . Both HD are connected onto the MCP (...
SO, How about the registered DDR RAM used in AMD Athlon64 FX systems.. Is it two different kinds of ram? thx a lot
What are the diffreneces between DDR registered and DDR ECC RAM??? THX :)
Both of them will work . In the second idea , I suggest you use a switch rather than a hub. A switch acts better in LAN if you uses file sharing ....
nice window design! I feel interesting in your tanks ..? in your HO2 cooling system. How do they rock?
I just started to build and setup my own web server (PIII , 128MB RAM , 15GB HD) . I probably will be my FTP server too. more HD space...hehe .....
THx. I have that route. I also found out that I can access 127.0.0.1 or 127.0.0.1:9727 once in a while (it's the settings interface of the web...
Yea.. I know it is loop back.. I am trying to access it though the machine that installed the web server program. Sometimes it works , but...
I installed the keyfocus web server. My connection is fine and my PC directly connect to the internet. When the welcome page poped up, I noticed...
Yo ! really great ! Can't wait to hear how they rock :rock:
cool ! I don't even notice that !
How do you do the bondo job? What material do you need? Doesn't it work with metal? Is your front bezel metal or aluminum?
I agree in some points of diehrd 's suggestion . Is there any 45 degrees fittings? I never seen any for PCs. You can find some or make some...
But if you use Y-fittings to seperate water blocks . The water will flow faster on the part(block/s) with less resistance . But it will flow...
Do you mean 5/8ID ? In his project , If he change to 5/8 . He needs new tubing and a new fitting for his reservior . But , the main point is...
