[img] This was modeled in Blender, and rendered in my own raytracer for my university graphics course. The modeling, and rendering (which took...
It loads up fine for me. Perhaps it's got something to do with your cache? Putting the CSS file in the HTML file wouldn't make a difference as far...
Needed to set it to boot from CD I bet?
Ok, here are a few commands that you may need. ls -- lists the contents of the current folder. ls -l -- lists the contents of the current...
Ok, there are many distributions to choose from (I'm running Fedora Core 3). When you install linux you're given options as to what you want to...
Can you get full acces to the internet via the wired PC? For my wireless router a flashing ADSL light means that the ADSL line has dropped or it's...
Share the drive that the folders are on?
I think that this is a problem with user accounts. You'll need to create a user account on the 2000PC exactly the same as the one on the XP...
Linux boots fine from SATA -- onboard SATA RAID contorller on an Abit NF7 (I had mandrake 9.1 installed on my windows box, but I uninstalled it...
In my setup I have the wireless router set so that it assignes IP addresses dynamically (by DHCP), and the wireless card in my PC set accordingly....
Here are a few sites that may be of some use. http://java.sun.com/j2se/1.4/docs/api/ The latest version of the java APIs (used to look up...
1.) I should think that most (if not all) wireless routers come with some ethernet ports on the back (the one we've got here has 4). But then...
If I've understood it right, you've not got any access points am I right? If this is so, then set the wireless cards to 'Ad-Hoc' mode (as opposed...
I know that there was a security flaw in earlier versions of Mozilla (the whole family of browsers) where a site could spoof the UI. This is a...
requery the data after someone bids on an item that's in the list?
http://www.colorschemer.com/online.html Color Schemer - Online Color Scheme Generator I know that this is designed for webpages, but I'm sure...
There is a good SSH client for windows called PuTTY. Get the latest version, as there are some security flaws with the older ones. (The password...
Put this function in your code somewhere, just copy and paste. Then call the function.
In it's most basic form, all you need to write is: BufferedReader reader = new BufferedReader(new InputStreamReader(System.in)); String...
Can you post the whole code?
