Howdy yall, I am looking to get an aluminum case for an upcoming proj and I have found a few. Keep in mind that for this project there will be...
not muted, tried with speakers and headphones, all working fine on a different comp this morning. Looks like I be getting a sound card.
I just transferred my comp guts to my new case and everything works fine EXCEPT I have no sound. My mic is registering input when I talk into it,...
ebay has em cheap, but believe me you get what you pay for. dremel and file or spend the money for some decent hole saws
My current project is with the hydraulic case from directron and overall I am very pleased with it for the price, very mod-able
I had to "help" a lady at work, she wanted to view a webcast in ie for whatever purpose, they told her to I guess, but her homepage was set to...
I haven't worked much (at all) with small dc motors, but I wanted to give it a shot for my case. The picture is pretty much what I built; a...
well got the knobs off, looks like it should be pretty straight forward to trim those pots and knobs down, I'll probabaly go ahead and paint the...
lol got to make a mod out of it some how!
Ok so take the knobs off, grind a little off the pot itself, and put the knobs back on...that way knobs don't get screwed up, thanks!
I recently bought a super flower fan master fan controller and I have one problem and one question about it. I test fit it into my case and which...
Its not even that complicated, and I found the problem, the solution however is probably not practical. I must have done something wrong or it...
go ahead and delete this thread I figured it out. Thanks
So this might be posted in the disaster section, but since it is not a complete disaster only a slight problem I will post it here. I recently...
