Cool thanks guys is their any point in me going for the Asus Crosshair V Formula Motherboard vs Asus Crosshair IV Formula ?
Hello, Im putting togther a new system for my self. I have a AMD Phenom II X4 975 3.6 GHz Black Edition and need some suggestions for a mobo. I...
Hey guys. I am just woundering if anyone knew the best way to cut out the letters on the keys. I want to then stick red leds in each key to back...
rite change of plans i decide to drop the hole only counting up to 88 thing so this is circuit diagram i made after your help [IMG] now i jsut...
2 qs what is the 1 - thing ? 0 and what compent makes the thing in your diagram called clock and how do i connect the...
Hey guys i was woundering if anyone knew of alt that look like this hv vacumm tube relay. [IMG] or any ideas how i could make something that...
dude thank you for helping be i am very new to eletronics and your digram looks very complecated. lol errm any chance you could explain it and...
hey can someone help me desgin a circuit that counts up to 88 that uses 2 7-segment display. so lets just call the first display 1 and the seconed...
whats the diffrance between dvd-r/rw and dvd+r/rw
Hey guys i'm in the market for a dvd writers and some blank dvds and i was just looking for suggestion on which to get and how much i should...
hmmm i like the way you thinking. But i still think i should paint the tubes.
Hey guys. I need some help. I have an arylic tube that i want to use in an mode the trouble is its clear and i need it to be green. What type of...
anyone know which way the maplin version is wired up.
Hey guys. I'm desgin a case mod and i am stuck 4 ideas. I would love any input on what i have so far. The theme is nucler power [IMG] Thanks
Grrr i can't find anywhere to buy wire to use for modding. Where in the uk should i look What kind should i be looking for. Considering it...
Hey guys i am using this thing called a giant red led in my mod but i have no idea how to wire it. It got 12 pins on the back of it spilt in to...
Hey guys i am do a big nuclar case mode and i need some help. I have found an image of a control box which would be perfect for the case i am...
where can i get green uv acrylic tubes in the u.k?
not sure yet i could. I was just planing to have them just for luck. If i did use it for water cooling could i still put ccl in them.
Right i just spent all night think what i should do and i have come up with this so far. [IMG] Well i am tired now and i can't think of any...
