Hi everyone, I tried searching, but I couldn't find anything too similar to what I was trying to do, so I'd figure I'd ask. I want to build my...
Sorry about the long delay, but I don't have much money right now and I just got into an accident (last night, not alcohol-related, just an OD of...
Okay, here are two more pictures of the paintjob, I recently got a Dremel, so once payday comes, I'll hopefully pick up some tint and acrylic and...
I recently bought a Dremel MultiPro for my current case mod (for which I have a log), and I'd like to cut some windows. The problem is, I need to...
FireFTP? I've always used it and it worked excellently, as long as you configure it correctly.
The painting is completely finished, I will take some all around pictures tomorrow when I get back from work. Many of the accidents from the...
It seems like either the PSU is crapping out (although not entirely, with the power light being on...or do you mean the motherboard battery?) or...
Here is the paintjob, as you can see there are a number of imperfections that will be rectified, and no, my carpet really isn't that yellow :D...
Here is the case before painting, after cleaning (amazing how dirty it still was), and after a sad attempt at ripping off the stickers (I still...
This is my first time doing a full mod (the most I've done is add parts, lights, sleeve cables, etc. on my homemade computer), but it hopefully...
Thanks very much! I've been looking for a decent DIY solution, and this looks great! I'll start to post a project log for what I'm working on,...
While you could do all this, for PS1/2 controllers there is a USB interface device (I own two) that can be used, and the same goes for most of the...
I'd like to see a tutorial on tinting acrylic plastic, especially with tint film. I'm working on a mod (linked in sig, will do profile here when I...
Well, PeerGuardian isn't a very good program anyways, people you may not want to connect to can have dynamic IPs ;)
I tried this and it worked well for a bit, until I had rebooted. The problem is, generally the MBR (Master Boot Record) is told to search for GRUB...
Hi everyone, this is my first post, but I do plan on posting much more (especially in the mods section, I am planning on a mod for a server to...
