shwang: All the help and ideas are welcome...I'm still getting all the works together for my comp mod. I was thinking of turning it all into a...
Aah...well, I don't really need it I don't guess...so, onward and upward!
A.P. what do you use it for??? i asked it earlier in the post but to no avail, I had no hits on that subject...
quick crap update... my trackman marble mouse [IMG] my dremeled keyboard [IMG] the trackman in the keyboard w/out the casing... [IMG]...
thanks, Wiz
I found a Toshiba T1600 [IMG] at a resale shop for 18 bucks...what do you think? Click Here for 1600
I have a ton of them...too bad they're too hard to get into.
is there a way to build in speakers to a custom case without harming any circuits or anything?... Also, is there a great need for the numeric...
Im building one in a Quasar vcr...Right Now!
I use this stuff called goop..."GOOP" household adhesive & sealant. clear/waterproof/paintable/flexible
any suggestions of what I can do??? :confused:
I didn't think about that... :wallbash:
thanks. I have a nokia 8250 lcd, but i want to use a sprint sanyo 4900 lcd. made by epson...is there some software for that???
no prob... :D
Would you need some sort of software to run it with the original circuits?...Anyone?!!...(malcs :worried: ) ::edit:: :eyebrow: I mean to change...
I worked on comps in a bolt manuf. shop...Pretty dusty in there! They had to have some special plasticy sort of stick-on stuff. Coz they kept...
thanks for the help...are the controllers hand made? I'm not too good with that :wallbash:
Any way at all? Or should I just buy something from MaxOrbital??
What I am planning to do is create a case with water-cooling and speakers built in to it. I will scan some drawings I did and post them...
This is my first mod and I am still getting all the supplies together. As I go along I would love some help and critique. Here is a few starter...
