thx for the response guys! does D-TERMINAL = dvi input? Monster63385, do you record via TV card? Is there another way to record of the TV?
My family is interested in buying a Back projection TV.. We are also thinking about building a home made entertainment pc for the new TV. So...
amm... The fact that i'll be adding 10 pounds doesnt matter, since the cam is going to stay in one place (facing the sky).. I just dont know any...
I was wondering If there is a way to connect a hard drive to a digital camera (video or still) ? If there is a way, how do I do it?
Is there a way to create a standalone web cam with a harddisk memory (so I can store large files)? preferably without a processor...
or even make it a finger print lock ... and it will also lock the power so you get a special battey that you have to plug in before you can...
why cant you just make a key lock that locks both the poweron button, the motherboard and the case it self?
is a cdrom strong enough to hold a glass cup?
how expensive?
I found a small psu for the seethrough case i'm building, but its only 200 Watt which is not enough... i need at least 300 Watt Does anyone know...
too rich for my blood... thats why i'm looking for the Lg one... its supposed to be cheaper
some one told me that the LG Cdrw-Dvd 10x10x24x8 Slim is a slot loading internal combo drive... unfortunatly, i've looked everywhere.. and I cant...
Hi guys, I'm on the first fase of building a seethrough case. I also want to make the case smaller then a normal one, and for that i need a...
cool where can i find an adapter? whats the adapter called?
Hi everyone, i'm looking for a slot loading DVD/CDRW(bruner) drive for a plexiglass case i'm building... since i want to put the drive verticly...
thats still alive... i think its on final development. a cool israeli company made it
any idea for stuff you can do with your other free hand? ;) ...........................:hip:
thx for the links everyone you freak! sup man! good to see you here http://www.icpc.co.il/ as you can see in the link above, they have those...
omg i cant belive it! its my lucky day! one of the only companies that sell a pci raiser is an israeli company!...
thx mate, I was thinking of using old IDE wires, will they be any good? I have an old pc that i can test this project on.. so i wont just...
