My main rig has an A8N-SLI mobo and its got 2x gigabit LAN ports. At the moment, it's hooked up to everything else on my LAN by a 10/100 switch....
I'd like to turn an old P200 machine I have into something that will help me with my electronics endevours, namely a dual channel oscilloscope and...
Now theres a good idea :) ta!
I'm building a simple PIC development board and I'd like a way to switch the I/O pins of the PIC between either an onboard device (lcd, buttons...
Can anyone help? I have the parts to build this now and I dont want to go shafting my ICs cos I used the wrong replacement parts!
Would I be OK to use a 1N1458 for the BAS16 and a 2N3906 for the BC807??
It's not a BA516, it's a BAS16. The schematic PDF is a little hard to read I'll grant you ;) See http://www.fairchildsemi.com/ds/BA/BAS16.pdf
I'm planning on building the circuit given at http://www.robot-electronics.co.uk/htm/srf1.shtml The diagram is for a SMD implementation of the...
Tried it on 5v supply and it gives me a nice aqua blue backlight, cheers guys :)
I've got a 2x16 EL backlit LCD that I removed from some junk PCBs along with a tiny little inverter. The inverter module is about 2cm x 1cm and...
Saw this on HardOCP: http://www.stanford.edu/~jstockdl/tmp/usbwifi.orcon.net.nz/ I had a cantenna made from a large tin of dog food, saw...
I mod xboxes and the flux pens work a treat for the LPC header... Also you can get fibreglass pencils that will clean the point ready for...
Thats a real nice looking project mate congrats! Of course I think we'd all love to see the circuit / PIC code! :thumb:
Or use a flux pen! They are dead easy to use.
I agree, the chemtronics solderwick is the best desolder braid I've used to date. I got 25m of some random wick off eBay very recently and it's...
Kustom PCs do em: http://www.kustompcs.co.uk/acatalog/Kustom_PCs_Shop_HTPC_Cases_96.html But they aren't cheap!! For my HTPC I ended up...
No on both accounts - TV is set to PAL/I which is appropriate for the country and I have tried all manner of contrast combinations, the TV always...
Are there any tutorials to get you started with Eagle that people would recommend? I am trying to make a simple dual LM317 fan voltage reg...
This is a funny one - In my experience with PC TV outs ranging from the old SV25 shuttles up to my current radeon 9600XT, you get coloured stains...
Isopon P38 or P40 filler :thumb:
