And one more thing. Never say: My system was worth 4000$ in 1995. That is wrong. Past is past and now is now. Zephyr told you the rest. And...
Yes, but you need a sensor that will react on vibrations of sound and that way make your UV lights blink. I don`t think that making something like...
Keep :dremel: I think that this is going to be a killer mod. But what about heat? Are you planning some holes for ventilation?
I do it the hard way - I push those little splinters inside the molex pin.
I`d say Never give UP. What is one disaster compared to a beautiful mod?
I sorta like it. Of course the visual is good but that is not called modding. Everyone can buy a case for 150$ and more bucks and put it shiny,...
Never promiss something that you can`t do... I am kind`a angry. :nono:
robotguy I think that this might be useful
Why are you all so agressive? There are noobs everywhere. Whats is easier: Telling 100 words about search and so on or 1 word like window?
You have more fans in your case than I`ve got in my conditioner. Great mod. Maybe add some switches or something so your mod can be compleatly...
I like my jobs to be unique. I hate making clones from other ideas. Peace :rock:
If you can make this work it would be realy cool. Have you read the article about fan control software? maybe you can adjust it so you can switch...
Well... I cut the plexi with a metal saw(don`t have a jigsaw :D ). But I sitck a tape on the place where I am going to do any actions. I use a...
I listen to music only in racing games or when I am playing something online and I need some adrenaline and will to kill... Rammstein, Manson...
I thing that 60w would be enaugh. If it isn`t a power hungry system then 60W would be just in time. P.S sorry for the bad english
