Aehiauuuh! :hehe: Excuse while I laugh my ass off... Against products like B&W Nautilus or even Gradient Revolution B&O is mere supermarket...
Holy forum-overload, Batman! What a reply... Why in the earth should you (you know who you are) quote all his worklog images? Your post is next in...
You're losing me here. Put the insulation mat (bitumen+foam) outside? Now that would hardly make any sense, since only thing the mat would do is...
Umm. Yeah, bitumen will block higher frequencies, however, in this case the foam is the one doing the trick (presuming the material is porous)....
Oh, my. I absolutely love the "turbine" look of those fans, what brand & model are they?
What liquid do you plan to use? Because the need of periodical coolant change was the reason I went back to air cooled setup. I have plans for...
Well, basically, all you need to do is; buy new Seagate 'cuda and peel off the label. The the finish on that drive is pretty much mirror-like.
Basically, this, like any other "what's cool" conversation, is pointless because people have the tendency to like different things. The one...
well, then... I stand corrected. It's just that you mentioned 3000 gamers before so...
"Dreamhack Winter 2005, the world's largest LAN party, in November." Hmph. The legendary Assembly, in Finland, has over 5000 enthusiast, from...
Nano ITX is pretty much as small as they get, measuring only 120 x 120mm. There's some pictures for you...
Umh. Project logs are ment to display the different states of your ongoing mod, hence you have to have something to show. That said, I think...
I say it once more. You can forget patenting this. Well, can't really speak for the US, since people seem to be able to patent the weirdest things...
That's a VIA Epia board which pretty much includes everything you need for a PC, in single board. You can get them from i.e. Coolputer. In...
I mean no disrespect but I think I'm sensing a tad of bitterness... Nexxo, here, made an excellent point. Ultimately, youre modding for...
Not to mention, if it would be bigger, it wouldn't look as neat as it does now. The window would reach over the plates, dividing the case, and as...
Fair enough. erm.. Carry on.
Well, to get even records you two should use identical boards (same revision, same BIOS) as manufacturers tend to calibrate their temperature...
Good god that's impressive! Although, a bit of critisism: H.R. Giger uses lots of sexual references in his works and I see hardly any evidence...
