Starting Over Again It's been too long since I haven't worked on this case... with not having any time to work it because of my band which broke...
Updating some of my pics that I need to. :rock: :rock: [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] :dremel: :dremel: :thumb:...
I bought Naval Jelly Rust Dissolver and I'm just wondering if that would work! And for my hdd window mod. epoxy adhesive industrial strength!
Yep $15.00 for the the whole computer w/ guts and all but I didnt hesitate to open it up and rip into it. Yeah I want to know what to use to do......
Sorry for the inconvenience... I used fileshack and will be using it for now on. Thanks Mr. Willy for your help. :thumb: :clap: :clap: :clap:...
Thanks I'll work on it. asap... would you rather i post a new thread or keep here? I'll get the pictures on and thanks again for the info. :thumb:
And photobucket and image shack happen to be???? dealing w/ a newbie sorry
I like the mechanism idea! Like the magnets and such or spring activated.... hmm i have two open drives sounds like a plan! :D
I think I might have gotten it correct because it was "[IMG]http://blah blah blah[IMG/]" But I can see it when you all say you can't.
That's odd I saw them w/ the preview post... Do you think you can let me know that way I can post them.
So I've been getting idea's from bit-tech for awhile now and I thought it was time for me to bust out the dremel :dremel: and make some mayhem...
So pretty much what you're trying to say that you don't like LEDs :D how about a UV reactive ram sinks or uv fans or uv on the whole mobo......
