Check out this thread. It isn't a complete list, but it should help you get started. Also, browse around the rest of the forums a bit. There are...
Thats not what he is looking for. That is a usb ethernet adapter. Oh, and good luck. This is something that I have considered doing as well.
Check this out (Search the page for 66702). The author states the possibility that the HD66702 is equivalent to the HD44780 controller. Whick...
Well, I do not claim to be an expert (I am not even close.) All I am saying is when a request originating from the internet is forwarded all...
Yes you can. I have been doing this for some time. I used to have a small ftp server at home so I could access files from school. I forwarded...
A good mod will void a warranty or at least make you think, "If I screw up, can I undo this?" Things like fans & lights enhance these mods. I mean...
You have to remember that you need the 20 Pin connector for the Motherboard. For the low power VIA boards you can buy from either iDOTpc.com...
