Entered.
I haven't posted anything here in a long time it appears. So hard to keep up multiple forums. Not to pull attention away from this fine site,...
Here here. During my upgrade I had no problems whatsoever. 6800 GS CO SE, 2 Gigs 3500 LL Pro, X2 4400, A8n32-SLI, Pinnacle TV Tuner. I didn't...
You are all right on all counts. We are in collaboration with Widow PC, Puget, Kustom PC, and a few others including a past (bad) experience with...
Latest pics [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
I'm not the man behind the company, I'm the modder behind the company. Some old guy still signs my checks. I could definitely send you just the...
No, we don't. We had a customer come to us and want a computer similar to there's. Vadim showed a V2100 that stated it had a decked out system...
Absolutely!! :hip:
My latest creations. [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
I've cut a TON of these cases. Bolt on windows are perfected by a piece of ABS plastic, painted to match, and installed between the acrylic and...
I've cut on all of the cases I've mentioned. What do you want to get out of the case I think is a very good first question.
TJ09, LL G70, P180, V2000, V1200... I'll keep thinking.
It's the exploding Sanding Band trick. The adhesive comes apart while you're dremeling, the band scrapes the case to an unusable state, so you...
I have a magic trick for ya. Turn this: [IMG] Into This: [IMG] Into This: [IMG] Into This: [IMG] Any questions?
Yep.
I didn't take the final pictures. We have an Alphacool CoolStar that holds two harddrives in the 5.25" drive cage. Watercooled, of course....
Here are a few pictures of two modded power supplies. Only the best. [IMG] [IMG] [IMG]
And one final post for the night... The great wall of Silverstone. [IMG]
Here is our newest Water-Cooled TJ07. GTX480 stashed in the bottom. [IMG] [IMG] [IMG] [IMG] [IMG]
I can't show too many pictures of that yet... we're having some problems with these new 8800's and the Striker Extreme. I can give you some case...
