After going through everything with the multimeter for the 10th time, is it possible that the UV tube is blown? it's not physically damaged or...
noob question, why the fire?
Ok. I just went through everything with a multimeter and found the problem. The 47uF 16V Radial Electrolytic Capacitor is blown. I don't know how...
Well, here's the thing. The inverter is kind of like a 2in1, (neon light and flashlight). I removed the light bulb from it's holders that were...
I tried both 1 and 2 without any luck. I was sure that it was going to work too, it was a good idea. The copper brown looking stuff is the heated...
Alright, here's how I wired it it up: [IMG] Here's the inverter: [IMG] It may not be totally clear in the picture, that's about as...
Didn't work. I'm sure it would have, too. Everything's wired and soldered correctly. I have a feeling that I'm getting the wrong voltage. Does...
Nice, I'll get to work on it.
Hey, I bought a 6 inch UV "flashlight" this past Halloween and now I would like to put it my case. I have 2 questions: - Are these UV lights...
They both look pretty sweet but I would go with the second one. You're cutting it out with a dremel right? On paper it looks small, maybe when...
Damn, heh. It's because I've seen people use orange and yellow plexi while working fine so I thought any plexi would do. I'm not going to give up...
Hey guys, I just made a glow pad, pretty much like macroman's mousemat. The thing is that all the LEDs light up but it doesn't go through the...
Ya, it's basically 4 series of 3 LEDs in parallel... I find it easier to work with when I do the real thing instead of making it all compact... ;)
Based on this thread, I've deseigned the circuit to go with my project. That's basically the shape I need it to be and just want to see if there...
Tattoo parlour... They mostly only have small deseigns in their books or on the walls. If I were you, I'd just come up with something totally...
Oh, best=fastest? ok cool.... ;) thought it was price vs. performance.... ;):naughty:
The 2400+...
Heat strip bender, heat gun.... same thing ;)
Heh, ya, I don't think there is any other way to do it without using a heat strip bender... :brrr:
I've seen it done before.... Doesn't mean it's garanteed to work though. I know you can't shorten a rounded floppy cable though.... Sorry...not...
