annother vote for york, i would reccomend you walk along the city walls tis a great way to see the city.
build a space ship, then go live on the moon!
Just experiment, everyone's setup is different. try it passive, and if the cpu is too hot then use the fan.
Anyone notice its cheaper to buy XP home and a upgrade pack than the full versions??
How about SENNHEISER PX100, great sound and they fold up aswell.
Get Seccond hand from ebay, I've seen the C320 (not BEE) go for around £50 which is an absoloute bargin as there are only a few small differences...
Take a look at http://search.ebay.co.uk/vga-scart_W0QQfrppZ50QQfsopZ1QQmaxrecordsreturnedZ300 quite a bit cheaper than that vga box.
Why not use your pc? maybe with a better sound card: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=157223 Much cheaper and easier...
Both cards i mentiond are stero only, designed as studio cards with good quality input converters aswell as good quality outputs. Problem with...
Whats your budget? something like the emu-0404 or the m-audio 2496 (both about £60) may do, but pc's are electrically noisy, so an external dac...
true, i was actually talking about the Audiophile 2496.
Just remember the m-audio cards are a semi-pro card, thus tend not to work with games and put a bit more load on the cpu than the x-fi would, but...
i know current and voltage are linked, (so it is always a combination of the two) but it is the VOLTAGE that is dangerous. Put it this way you...
I know this has prob been asked before but i cant seam to find anything on it. I have a 160gb Maxtor Diamondmax plus 9 with two partitions on...
I'm sure i read somewhere that the more powerfull a pelt is the less efficent it is, so doing somthing like this you could use a larger number of...
