i did the same exact thing. had a nice 160gb for a liong time almost full.. sleeved my whole powersupply and the next thing i know my 160 is...
yup i have done it but be sure not to bend the wires alot or else they will snap
a deeper green would be better imho
man i must say this is come classic work you have here. i have thought of making a wood case but out of oak. this paduk looks great.
psp3? isnt it the PS3
ive got basically the same setup and you cant really go to high with it. mine wouldnt post past 182
well i care, sledding is pretty fun. i dont own one my self but i use my freinds brothers when he isnt around. some type of polaris one i...
i wouldnt call it a doll. i cal my sisters old barbies, dolls. anyway awsome gift there mate.
yes jumper is right. most if not all .mp3 files are not surround. pop in a dvd with 5.1 and then listen. you wasted time returning the stuff to...
my bad jumper
yeah but what he is saying is that when he runs the test program it uses the left front and right front for all of the sounds instead of having...
ive got the x-530's and had the same prob with a creative card until i did soe looking around in the options. you have to set our speaker...
found this card. read about M-audio and they seem to be pretty good. here
found drivers for it but creatives site is being gay and download wont start. im open for suggestions: what would you guys here on bit-tech...
k thanks. i guess ill buy an audigy 2 zs or something
yeah i know, i have the asus sli mobo right next to me. but i didnt realize it was agp cuz i didnt read all the specs, i just jumped on itcuz i...
was about to purchase two of these cards for an sli system but then saw this review and it said they couldnt run sli...bummer. i just may buy a...
i bought the logitech x-530 5.1 speaker systems a few weeks ago and they seem to be pretty good with listening to music and dvds, ect. but when i...
thanks puggy!
thanks for the info. do you just order the retangular window kits and just cut up the acrylic? since $$ isnt an object right now where is a good,...
