How about running Rempote Desktop on the main PC? You could then open the PocketPC client and run MBM via that.
Well put :) And PLEASE no-one mention resistors and pots :duh:
Oh for gawds say! How pedantic? :rolleyes: I should have said "The wires you need are the yellow and black ones" Leeum: If you follow A88's...
Hang on, thats not right... The fan gets its power from the yellow (12v) and black (ground) wires You need to connect the red wire from...
That only works out if you have a full bus! I don't know about London, but in Bristol, it's rare to see a bus with over 10 people on it. In...
Aren't they the holes the plastic lugs on the back of the bezel slot into?
You know all the specs and pics are on the Lian Li website right? :worried:
Whenever I do any wirring in my house I always take a few digital pics for reference.
White plastic don't come cheap ya know :naughty:
They are both solidstate MP3 players that plug into the USB port. Not similar enough for ya? :)
The Shuffle is just like any other solid state player, like the Muvo etc, except for one thing: iTunes. The power of smart playlists...
I totally agree Jazzle, I'm just bored :naughty:
Well the footer on DigiKey says: "701 Brooks Avenue South Thief River Falls, MN 56701 USA" I'd say its in dollars :) S
Nice work! Where'd you get those shinieeeee hose clips? S
I find when I do that the water level in the res rises - surely that means there is air creeping into the res and forcing water out? I bleed it...
How big is your paging file (virtual memory swap file)? S
As long as you dont mind drianing and flushing your system :) BTW: ANyone else using blue find its not very UV reactive and quite dark? S
I'm pretty sure someone has clad a Swiftech in plexy and make it into a waterblock. I'll try and find pics S
http://www.formfactors.org is your friend :) S
Thanks bradford010! That's a lot further than I had got up until now :) Any ideas what they charge for UK delivery off hand? S
