My little one. [IMG]
BMW 320d coupe, 48mpg from a tank is bad news, in semi-decent traffic and journeys, about 54mpg (in theory it's supposed to be nearer 60). Seeing...
Gents, I could have sworn that Five Live reported at five o'clock on Friday night that Sony had apologised to C of E because no one had remembered...
Clarke actually wrote a paper on using satellites as communications devices. He calculated the required orbits and went into a lot of detail on...
I just got one for the exact reasons in the review - re-use existing components. And I had similar problems with the vfd not working - even when I...
I got an e-mail from Seti saying exactly the things said here. It isn't gone, just moved over to BOINC. Really inaccurate reporting. :sigh:
It strikes me that what has been noted as criticism would probably go away entirely if you were using a Pentium 'M' processor with, say, the new...
Apologies for the huge delay in answering. Norton Internet Security was blocking it so I added trusted computers and used the IP address range...
Mainland China doesn't have the technical ability to invade Taiwan, so far... And as for numbers being the most important aspect, First Gulf War...
Handkerchief in right pocket, NEVER left pocket, money in left pocket, NEVER ... you get the drift :blah:
Problem solved. I'll try to make the next one more interesting. :duh:
I have a D-Link router connected to a cable modem for internet access and I run 2k Pro on my desktop. I have just bought a laptop with XP Pro and...
Stereotypes aren't much fun for the stereotyped - as a Scot, I should know! One of the interesting ones I've found in real life is that the...
But there isn't anywhere else to put it. This is a fairly sad, fairly pointless quiz question but I wonder if there is anyone out there......
I had 12dBA Papst fans but they really didn't shift much air and after less than a year they developed a slight groan type noise in the motor...
80mm Accousti fans at Kustom PCs are 14dBA to 21 dBA depending upon temperature (they have sensors) 92mm Accousti fans - 18 to 26 dBA 120mm...
I'm one of the 8 but before you youngsters start crowing, advanced age and decrepitude has one advantage... if I want an £800 TFT monitor... I...
Go on!
Kustom PCs are now doing automotive quality case painting with matching keyboards. See link -...
Its strange that most of the new laws being passed - on both sides of the Atlantic, - would have the greatest effect if used against the general...
