Simpsons episode. Little leprechan on the Chief of Polices son's shoulder. "You done good laddie, now Burn them, Burnem' all" :) too much...
Dang!!! That really is some LOUD wallpaper... :) :D
So whats the best board that will also run standard pc100 pc-133 mem? I currently have (2) celeron 500's on a Abit BP6. Best board I have ever...
Will the KR7A take PC100 and PC133 sdram? Just wondering...
Unloaded: Electronic Goldmine a goodplace to buy from? Hows service?
Anyone order from them b4?
Henry...I have a question. I finally got around to really putting stuff up on the LED (tie, date, scrooling, etc) I noticed something, part of...
Excuse my lack of Modieness ( :) ) but, where did you get the heat sinks (model #s?) and HOW did you get them to stay in place? The only way I...
It does need to have a resister, etc on it right?
There a particular reason? :) (If I do I'll add the extra pieces to stop it feeding back and blowing the gpo)
To bring it to work next morn. (Got a T1 at work..:) ) I seldom do it but when I do it bites...
I have a ODD problem. Seems if I leave my PC unplugged for say overnight and try to boot it up it wont come up till it has been plugged up for...
Gonna "knock up" some blowholes? ;) Sounds kinky.. :) Haaaa jokin'
Not sure. Got them from another Mod site...they look good.
I got the template for the 80mm fan cutout if you want it..e-mail me at: eadams@ptl-inc.com and I'll send it to ya. Got the 120mm and the 92mm also.
:) I personally know people that check e-mail once a day so I figured if nothing else I bet you checked this forumn every 5 sec or so.. ;) Like...
Gracias to Henry at MO for the sweet service and the A1 LCD!! I just believe if you find great service somewhere you should pass the word along...
I am sure someone here has tinkered with it so: My problem is I installed Winamp, installed LCDriver 1.0 and how do I get winamp to use the...
I was wanting the bio-hazard image. I want to print out a template like Macroman (i think) did and make that cool lighted bio-hazard button like...
How was that lighted Bio-hazard symbol done? Sweet...
