That's so awesome, love to see the worklog of that. Dunno how anyone could fit that easily in his room though, you'd need to rent a lift that...
I hope I got the question right :worried:
If the games have to be so expensive so that they can earn there money back it's not overpriced. If it were any cheaper they would loose money,...
I have one of these and I used it to make a torch. Well, actually more a coca cola can with batteries inside and the luxeon on top. It gives...
Wireless power? Since when is that possible? :eyebrow: I'm interested though in which way you're gonna try to levitate it. Magnetic field...
I got it to work :) But it's a matrox millenium. When I finish building it in my case I'll post pics to persuade all the others still considering...
that's the strange thing. I measured to see if there is a connection between the board connector and the vga pins and every pin seems to match to...
I'm finally able to get a picture on my psone screen. It still has some diagonal lines which shouldn't be there but that's not the problem. I...
Actually, power lines are good. They break your fall and because you aren't grounded you won't get chocked. I heard about a man who fell on...
from what I've learned in school it's just something that you put around the wires. In this case the shower tubing. Very nice mod, if this works...
New update guys
Sorry for the long time without updates. I had a lot of schoolwork and I'm (still) waiting for some plexi to arrive and making a welding...
What are you trying to compensate? Hah, just kidding :p lol I have the same problem (I mean with height dudes!! :p) Love the way how you will...
10 leds varrying from 0 to 100°C/F I suppose? (not that it would reach that). This would mean that your temperature has a fault margian of about...
the temperature of the vapochill says something around -30. This is actually not a number you can rely on because it measures the temperature of...
new update
Time for a new update. This time I got my vapo back from a great guy , Jort - a belgian phase change guru-, with a longer tube, a regass and a...
I like the uv yellowish/greenish plexi behind the splinter cell logo. It reminds me of the glow of Sam Fishers's glasses. Very nice choice....
So, first update of the project: the bottom compartment. This will house the waterchiller and will not be fixed permanently to the case. It will...
I vote for feeding frenzy, the details and all, it's awesome.
