At the begining of this post I was going to suggest useing laminate instead of paint, but that is before I saw where it was going. This project...
Recreate it in photoshop and print it on a high quality printer useing sticker paper. This helps in two ways one, you get rid of that ugly rip...
Is there a link to see all the finalist cases? I have seen the matrix 8.0 and the M.Falcon ones so far. Zap's case still has my vote out of...
You could try nibbling cutters, although they are pain to use and don't cut holes very well. http://www.directron.com/nibbletool.html I...
I already dyed the controller, charcoal and white, but there is some cracking and peeling where the to colors meet. So I wanted to put a clear...
One this same topic, has anyone tryed putting a coat or 2 or clearcoat on a Vinyl Dyed object? I want my dyed xbox controller to be glossy....
http://www.frozencpu.com/cgi-bin/frozencpu/scan/se=Cable%20Sleeving/se=Sleeving%20Tools/mp=menu_search.html
The plan is to sandwich a piece of lexan between 2 aluminum disk and put a led in the center.
Nice, I would only need 8-10. While I'm at it I might just order some custom grills too.
How about a little mod guide when you do so, for the electronicly challenged.... :D
Ok how about you slightly recess the drive (like 1/4" or 1/8" back), then cut the face plate sides to make it one flat piece. Attach a slim hinge...
I'm going to create my own custom case feet ,so I am looking for some aluminum disk about .25" thick with a 1" diameter. Is there any sites that...
You could always create a wood template out of scrap wood to match the contour/radius of the door. Then just bend the metal sheets over the wood...
Hmm never thought about it like that, might just have to leave them as is. Thanks
I guess if you like the taste of cancer when your gameing, this is for you.
With knowledge comes new questions! I realize my question was answered, but the answer leads to a new question. Is there any mod/work around to...
Wow! First, thank you for the fast response. Second, thank you for the welcome. I'm glad to be here, I have watched from a far for a long...
**Warning** I am very new to modding and I am also at a lose when it comes to the inner workings of basic electronics **Warning** Is there any...
