Can you only order the i£ version now, or have yo considered the AMD E-450?
Thanks for the reply, but you should treat me as a Linux noob. I used to use Unix at Uni way back in the mid-late 90's but frankly other than a...
Hello all, and a Merry Crimbo to you all ! I git my 11 year old son an Acer Aspire One (Linux 8gig version) for xmas and he likes to play...
eee pc 900 (XP) - love it! Was gonna get the linux one but out of stock and I had itchy fingers!
Just got COD4 for 360 this xmas 0 gotta say I love it! Stoppedusing the PC for gaming since I got the xbox and 1080p TV really. In a couple of...
eek - thanks! Works a treat. I was messing around with loads of different permiatations of the code last night but thanksfully you know what...
Hi all, After some help please with asp pages and query string. I have an access db on my server which I want to be able to query using an A-Z...
I have a SN45G, I had problems with mixed makes of RAM, but now I have PC3200 cheapie stuff from Aria and it works a charm!
I've used some different types in my SN45G before, however I currently use 2 x 512 sticks from Aria - about £22 each - 1 gig for under £50...
I get this problem 99% of the time, I say 99% as I've only ever played it on-line once! Every time I try to play online I get a connection...
OS X has a built in FTP server, switch it on and you can just connect to it over a network (or cross over cable) via internet explorer if you need...
It's the Shuttle 16 speed DVD burner. I did have a normal beige 4 speed DVD-R in there with a coolermaster facia on. The coolermaster facias...
Thought about it, but didn't want to risk scratching it.
It is quite quick and easy, but to get the silver line off the plexi takes forever and a day!!!
Did the facia of my SN45G a while ago now. I removed the silver bar on the plexi using toothpaste and a LOT of scrubbing..... [IMG] Oh, I...
I also read an article which suggests that a Firewire 7200rpm drive gives nearly a 75% increase in performance....
Looks the business! Love my iBook to bits, so can imagine what you think of the powerbook! Like the look of the stark mouse, but read some bad...
I have no probs getting onto my Shuttle's NTFS drive from my iBook. I have some folders and drives shared on XP, can connect to all of them via...
Hi guys, I bought my G4 iBook nearly a year ago for exactly the same reasons as yourselves. I was using a 2GHz Toshiba laptop with a 15"...
My 12" 1GHz iBook. Love it to bits. Since getting it about 9 months ago I use it far more than a PC at home. Still use the PC for games, but...
