it is an Abit SD7. The CPU temp now reads 28C at boot and about 38-44C on a full load. The motherboard temp is still reading 66C though. I...
well I went ahead and got the 1.8a and the SD7. It fires up with no problem to 140FSB giving me 2.52 stable at 1.75V. MIPS are at 4725 (made...
I have a brand spankin new P4 1.8a and Abit SD7 mobo and the temp readings are rediculous. Occationally it is correct for the CPU (28-32C), but...
I'm seeing some pretty convincing information on the P4 1.6A, such as: http://www.hardocp.com/reviews/cpus/intel/p416a/ Also you don't have...
Pricewatch lists the following prices: P4 1.6 - $136 Abit SD7 - $95 XP 1700 - $114 Abit KR7 - $115 As you can see, the prices are about...
It's some sort of plastic...my father is a photographer and it was in his collection of backgrounds. He has a huge sheet of it and i cut off a...
my first case...wall mounted! [IMG] [IMG]
i got some extra mounts from a local parts store...they gave me all i needed for free. i mounted my mobo and ps to the plex by drilling holes...
don't glue it, drill the holes with a 1/8" bit
Since Cool Hand mentioned the aquarium, here was my REAL first custom case...heh, nice photos too... [IMG]
Ok, another pic, and this one is blue! [IMG]
No, the drive is a standard internal slimline DVD. It came out of a Dell laptop.
I tried adjusting the levels in Photoshop but I didn't like the results...
I ordered the PCI plate from: http://www.addtronics.com The slimline to IDE adapter came from:...
Very interesting you say aquarium. The computer was inside a 10 gallon aquarium for 3 months while I planned and built this case. It actually...
The case Wow...lot of replies. Ok, here's the deal. The case is mounted on the wall, the cables are all connected in that photo, they run...
The system is not finished, as i haven't added the LEDs to the front, cool cable wraps, and my cathode light hasn't come it yet, though the case...
Radio Shack...I only had 2 small white ones and after I put the first one on perfectly I accidentally slid the other one near the solder area...
I removed the cover from my power supply for a plexi case I'm building and I need to remove the switch and wires for the 110/220 converter so it...
