Try running some testings, fitting a fan temporaly to blow air into the radiator from the top. If there is alot of obstruction of airflow in the...
Same here, the Stacker is a great case for fitting w/c with minimum or no modding required.
I will have one in the flesh early next week - they look abosolutely amazing. By the looks of it, you might be able to make it bigger by adding...
Yeah I believe we are getting all that stuff! Definately the Tygon tubing as its meant to be the best you can get + all the fittings. 100...
Just so you know the two Alphacool units Fibbles posted above are meant to be hot sellers with Alphacool so we have been told, hence why were...
I can confirm that there are no UK stocks of this case. It was discontinued a while ago now along with most of the range.
You would most likely have it on the 3rd January assuming the item is in stock. :)
As far as I am aware they use 450w PSUs.
We have them at £59.91 delivered if your interested: http://www.thecoolingshop.co.uk/tcs/comersus_listcategoriesandproducts.asp?idCategory=9
Wow, Ive never seen anything like it. hehe
New XX-Flow blocks from Innovatek look good, but I personally love the look of the new Zalman block.
I would recommend Innovatek kits as I can personally say that they are extremely well made (german engineering). They are extremely popular,...
Make sure that Anti Alaising is turned off, and that image quality is set to High Performance in the driver settings. If AA is set to 4xS in the...
You'll prob find you will be paying an extra £17.58 on receipt of the product from UPS, this inlcudes taxes and their £10 fee. This still makes...
lol :rofl:
Cheers :)
You should have it tommorow hopefully :) (1st Class Recorded).
Also, The Senfu temperature monitor uses the flat probe type, but there is a point on it where pressure must not be applied.
What is it with Price Rises. Memory has gone through the roof recently :mad:
We did a lower price over the Xmas / New Year Break. Its back up by 70p now though. They are pretty cool for modding into blanking plates....
