Half way through the dl now ;) Can't wait to give this beast a whirl..
Personally I wouldn't recommend going lower than £350 (in terms of what's available at the moment). This with usb3...
for the hd try the seagate barracuda ST500DM002. Generally the cheapest at the mo, can be found for £63. No need to stretch to a 460/6850 for...
Hello there, To be honest if you're still playing at 1440 resolution then that should be the first area you address, especially when you consider...
I'm in same position, picking up components as of tonight for new system. I went with the gskill ripjaws (F3-12800CL9D-8GBXL) because of the...
I was thinkin of the h61 boards for example as those seem to come in considerably cheaper. Any reason not to?
Hey mate, generally no (in terms of amd), the 2500k would be the way to go (or certainly the 1155 socket should budgets restrict ppl from...
Hey guys, Was planning on getting an i5 2500k but managed to get a 2400 second hand for a decent price and so am happy to stick with this (not...
Hey folks, I'm looking to put together a system for a friend on a limited budget. It will be used for general tasks and a little gaming...
hey there, Can't help you in terms of motherboards exactly, as I'm in the same boat as you - seeking info on sandy bridge motherboards. But was...
J firstly you're assuming I haven't tried lower settings, which indeed I have, the lowest infact, but as I point out anyway, this particular error...
Ah forgot to pop the graphics card details on there : Intel® HD Graphics 3000. And no guys, its not an issue with the ability of the graphics...
Hey folks, Apologies in advance for this, given that I'm well aware there are plenty of threads out there concerning this. However, its gonna...
Hey mate, generally speaking in terms of decent gaming performance, the gpu is more important than the cpu. Personally, I would swap the...
Yeah should be great mate, think I'll pick one up sometime soon for the second hand budget gaming rig I'm looking at building for my brother....
His mobo's coming tuesday, convinced him to go for the same one, think it'll be a great board for what we want ;)
Porn will never look the same again ;)
it'll do very nicely for ALL your gams at that res bud ;)
Yeah supposed so be a great budget board, essentially the same as the 770 and only 48 on scan...
Tbh as others have said, I'd personally have dumped the 2500k and mobo, picked up something like the p2x4955, m4a88tdm and kept the 460 1gb which...
