Thanks Big Elf, I think I will run it right after the 750 at 12v to reduce its strength and go for silent operation. I did tried to remove the...
Hmm, I will be doing both the CPU and MVF and the only reason im sticking with the Bay Reservoir for now is because I don't have a reservoir by...
Hey everyone Im slowly gathering all the components to start a new build in a Phanteks Enthoo Primo Case and had a few questions/ideas I was...
Thanks for the great suggestions guys. So i think i will get the graphic card or cpu first then sell my current cpu and board to pay part of the...
So i recently sold my dual 6950 and got a gtx 680. I managed to get some more money in my hands and i was wondering if you were me and had the...
Thanks everyone. Assuming I went with a i7-3970K instead of i5 do you suggest I wait till Haswell? I plan to overclock it to about 5 Ghz slightly...
I was thinking about upgrading to a GTX 680 or i5 3570K + Asus P8Z77-V DELUXE Mobo and wanted to get some outside opinions on what you guys might...
Yea the Batman scaling threw me for a loop negative scaling been a while since I saw that outside of the 6990 and 590. Regarding skyrim, from...
Just put together an AMD CrossfireX vs nVidia SLI Scaling (2-Way) graph for though who are interested in seeing how the two cards scale across...
Moved to New Thread - Sorry about hijacking
Thats a 100% overclock but Im guessing it was using N2 seeing such a high vcore. [IMG] [IMG] Source:...
I'll give those two a try. I've actually tried a lot of the guides on the web including the one on Bit-tech and found those unsuccessful which is...
I've had my current i7-920 Since 2009 and over the course of its life I've tried many times to hit 4.0 GHz while being stable with a vcore of...
Yea I'm surprised it didn't melt or burn into the CPU block. Maybe the thermal grease kept it intact ? I used Arctic 5 Polysynthetic Silver...
Alright I think I'll try re applying the TIM again and post back tomorrow. The fans I'm using are: Pull - 3x Yate Loon D12SL-124UB 120mm - Rated...
I finished my water cooling loop about 2 months ago and I noticed my idling temps from the get go was: Core #0 49C Core #1 48C Core #2 48C Core...
His site seems to be down too i keep getting 404/ Forbidden Errors
First AMD 7970 Benchmarks Released. It has a long advert at the beginning but if you bear through it you'll be in for a great surprise. Don't need...
Yea I can afford to wait, best to double check and get it right the first time. I did read the log but it looks like Pete isn't a fan of barbs =O...
Thanks Big_malc, I don't like the look of the hose clamps either but its just a temporary solution until I get compression. I do have the...
