I had the same fault on a system a while back and it turned out to be the thermal paste. If it were me I'd at least start by removing the cooler,...
Was thinking about this program a few days ago when I was cleaning someone's system. It used to be a great piece of software but I stopped using...
I'm looking to put together a system for a friend which he can use to monitor and control a single camera. He's been having complaints that his...
Tom's Hardware Best Graphics Card for the Money November: http://www.tomshardware.co.uk/fastest-graphics-card-radeon-geforce,review-32316.html...
+1 to the BitFenix extension cables. I only just purchased an extension for an 8-pin CPU power cable and was surprised at the quality of the...
Really, no matter what else you upgrade, you're always going to be limited by your PSU if it has no 6-pin PCI-E connector. You can buy adaptors...
May be worth asking at your local electrical wholesalers, I would have thought they'll know more about this and where to get it from.
Just to let you know, when I contacted Scan about RMA'ing my PSU they arranged a next day collection of my PSU with DPD so I didn't end up paying...
That's the only issue I had with returning my unit to Corsair. I worked it out to be around £40, but that's around the same cost as the CX 430 so...
Do you have to pay to send the PSU to Norway or wherever Corsair are based? I'm pretty sure I looked into this instead of RMA'ing to Scan, but it...
Can't comment with regards to the modular cables but I recently returned a Corsair CX430v2 to Scan for RMA. It was in my brother's system that I...
I popped all those items in my basket and I make it £238 without the HDD, and that's assuming free delivery of course :)
Yeah the definitely the self-build! Will be a much better system and you get the joy of building it! You could almost defintelly get away with a...
+1 I think those are rebranded Seasonic units so they should be fantastic.
I'd say leave it on myself. The cooling of the case is designed to channel airflow over the components of your computer. Part of what makes that...
Just incase you haven't settled on your choice of CPU yet, the following article from here on Bit Tech may be worth you having a nose at:...
Nice one mate ;) Grab yourself an SSD now and you'll have the hard drive rating up in the 7's too ;)
No BIOS configuration should be required for your CPU - as long as it's supported it should just drop in. At worst you'd need a BIOS update which...
A CPU will just drop into place, you shouldn't have to force it at all and doing so can cause the pins to bend or even snap which is a nightmare....
I'd doubt it's a bad install personally, have you checked your temps? I know you've listed several alongside your parts but are these at idle or...
