fail.
Another video link i can't find is the vvvvvvv video
where is the link to the youtube video of the guy with the assault rifle xbox controller.
May aswell buy a 5970
nvidia 6600, i was only twelve at the time i am suprised i knew what i was doing i can't beleive i managed to buy the right thing, tbh i didn't...
imma go with 11 fps
but can it play crysis?
the price you will have to pay to send back a case is monumental, so you are better off sticking with the one you have
i imagine that the cm 690 II is the biggest, i heard it has decent cooling aswell
yes with avforums
you should go for the oem version of the i7 930 as you are buying a cooler with it
dell s2309w
to get free postage sign up to avforums and make 20 posts then folow the link they supply you with to get free postage on your scan account also...
if that doesn't work just rma it
definitely go for the f3, also any reason for only 320gb version? edit: do you want to know how to get free shipping?
tbh i think a new computer is needed :s
so that would be in 1366?
how do you get the old ui back?
yes i changed my clock back to the original time it does nothing
