something like this is what your looking for....
Aahh! the cooling properties of beer.
Working on the assumption that the PCI-E power connectors all come from the same 12v rail in the PSU, would it be ok to daisy chain 2 graphics...
Does anyone know if there is a permanant +12v inside a psu so that I could use it to power the led ring on a anti-vandle switch.
Is this the kind of look your going for? [IMG] [IMG]
I don't understand, how do you mean?
So, I decieded to go ahead and make some slots in the acrylic panel. [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] Now, another question,...
there won't be a fan on the back plate as I will be placing a EK-150 res there. The fan I plan to put on the inside panel will draw cool air...
Nobody ever achieved greatness by taking the easy option :D I've made a modification to the left hand version, maybe that would work better...
I'll put a fan somewhere on this panel, maybe near the bottom. I'll cut a series of slots similar to the acrylic panel and mount a fan behind it,...
I do have a router with a 5mm bit, however, it's a one shot deal getting it correct. with that in mind, I have made a couple of sketches and...
I have a question before I finnish the inside of my case. If the motherboard and graphics cards are water cooled, should the compartment they...
There's no pcb at the front just a ribbon cable, [IMG] I would need a very small soldering tip to make the joins at the other end.
For my current TJ07 build I am using a stealth faceplate design that will also hide the eject button for the ODD, I was planning to use touch...
I bought some replacement buttons for the PS3 thinking that they might be more technical than they actually are, they are in fact just painted...
I had the same idea with my case mod, though I plan to use the eject button to eject a dvd from the stealth face plate on my tj-07 . I think,...
I've just set FSB - RAM linked 5:4 (1333 fsb - 1066 ram) still no dice, still getting init8042 on the poster. CPU is G0 stepping version the...
I'm trying to overclock this pos Q6600 above standard 2.4GHz on a Asus Striker ll Formula with nForce 780i chipset what am I missing? I...
