You can play the game in Russian w/ English sub-titles. That's exactly how I'm playing the main campaign of Metro: Exodus currently.
It doesn't cost you millions of dollars to lock your car door. It costs a lot of money to implement the most commonly used DRM schemes. Creating a...
I noticed when browsing to "http://mysite.no-ip.org" that it would just take me to the router page when I was on the network, and if I was...
the price/performance ratio of SLI really isn't worth it. You should just look to be upgrading to a newer card and selling your GTX in 6 months...
wierd, I didn't have this problem at all...
Chronicles of Riddick, as someone mentioned, has probably the best animated menu, or menu period that is, of any game i've ever played.
there is a patch for XP floating around out there, i'd do a google search for it. Its built into the Ultima Edition that floats aroun on P2P...
if you want something more commercial, Cyberlink just released their vista patch for PowerDVD
there is actually a new revision out that brings the foward button back! http://ve3d.ign.com/articles/772/772101p1.html
looks like a pretty weak nuke =P
its about the same, maybe 1 or 2c diff from what i remember. ceramique is applied in a line over the cores (if you're talking about dual core)....
have to say this is a gorgeous mod that has inspired me to take my next case and do more than I originally planned with it. The blocks are kind of...
as long as the advertising fits in its good. When it sticks out for a sore thumb then its craptacular. Like seeing an add for a Ford F150 in...
i thought it was pretty sweet, took me about 4.5 hours on hard, stumbled a bit in certain bits :wallbash: if i had paid 20 bucks probably...
yes digital VRM is teh hot... also to jack an idea from DFI, SATA connectors parallel to the edge like so: [IMG] sry bout the rough img ;P
