Recently I received a 7950gx2 as the rma replacement for my dead 7900gt. To make a long story short, I purchased the swiftech gx2 spacer kit in...
First off, thanks for the candid review. As most gamers probably do, I get bored with the "Hey check out the graphics on this new game" reviews....
That is one hell of a great/simple/elegant case mod. One of my favorite sayings is that you can't polish a turd. Obviously, in this instance,...
I have done that and also used the crop tool in gimp to trim off any extra space from the images, leaving only the motherboard image. I am not...
One option would be to edit the picture/image you are using as the texture in another program such as GIMP to the size you want, then import the...
@jezmck: I sent you a message via the contact form on the SCC website with the URL's for the skp and jpg.
@jezmck: Let me touch up the threaded ports for the barbs a bit and I will let you know when it is ready via pm. Then if you tell me what size...
First SU model Well, I finally broke down and tried out sketchup over blender. I must say that I find it very nice. Here is my first project, a...
I am in the process of relocating to another city, so the case is on hold for a bit. Once the move is completed, I will be back to work on it....
Although that is a good idea, unfortunately the radiator bracket/grill will be powdercoated with the rest of the case. Those will be built...
Even though I was headed to my in-laws for the weekend, I was able to continue my work on the project while I was there. Luckily, my father-in-law...
Speaking of suspension, in the early designs for the case I toyed with the idea of suspending the Hardrive cage with oil-filled rc car shocks for...
It would have to be a pretty small wheel and tire. Are you suggesting under or to the side installation? I guess I am not sure how small those...
I have considered that, something along the lines of the MAXX rims and tires. But, being an RC'r (Stadium Truck), leads me to believe that the...
It is pretty heavy so far. Thanks for some of the tips, I have notice that the grinder tends to mar the metal a bit too much. I will be doing...
Thanks, I plan to work on the mount a bit more tonight. It may take me a while to get it finished, but I hope that the time I spent planning this...
You would be correct. There is currently some solutions under consideration to making this case more lan friendly. I am considering either...
I've turned over a new leaf and my goal is to make small updates to the project log as regularly as possible. This will hopefully keep me working...
Customholle, Sorry about the serious delay in replying, I must have missed your question. I made a small update in the Project log today....
After a couple of weeks of slow progress, I actually have a couple of images to post. This first image shows me preparing to install one of the...
