first of all, sorry i have no updates at the moment my study is too time time-killing... :waah: in january i have my tryouts and then ill...
@all thanks :) but to continue with the project i still need some money for a new saw blade... but i can show you why the project was...
hi first of all thank you :) no im not infected with the "T" virus :D the main reason at the moment is the oktoberfest in munich...
thanks :) @mrgreen that is definitely the greatest compliment i have ever read :D :D @hydro_electric thats my opinion too nearly...
thanks :) as i wrote i have no digi cam at the moment, but i borrowed one of a friend of mine here are some pictures after all being...
im back :D just working on an new res [IMG] [IMG] [IMG] [IMG] these are the last pictures i have the res is now...
thanks :) @BlaZ3R yes its uv-plexi orange @Gambler i bought it in a normal home improvement store in germany @scifi3018 thanks :D...
thanks :) @Klikka_bZerk as i wrote it will take a while i still need some parts, some for the pumps some to get a good lightning if all is...
@hydro_electric_655 i think ill try both when its all finished i dont want to melt it ;) btw. the temperature to melt PMMA XT is over 130°c,...
the temperature ist 80°C and one hour for every mm material in that case it was 5 hours then never open the oven abruptly the material has to...
thanks :) @Kumo after the drilling and cuting the plexiglas is very brittle if you glue the material without this step the plexiglas...
Hi this is my actual nearly finished projekt: ceramic i started it in 2004 and after a long break i continued the last days it ist build of...
thanks :) @Klikka_bZerk its not from acryan i buy all my plexiglas from a local company @antiHero <german> ja, alle plexiglas arbeiten...
i have a big update first i got my new 7900gt card, and a black ice 2 pro here is the new black ice, and the aquastream in the case [IMG]...
thanks :) @zachjowi at the moment i am working on some al parts and the case itself but the main reason was a hardware update of my main...
thanks :) :) @JaredC01 yes with this block i wanted to try something new in this cooler the channels are perpendicular to make some...
i am back :D i a few posts ago i showed you my problems with the case i got a new one but this got some ugly dent too so i only use some...
thanks :) @Tulatin yes, that would be possible, but i dont think ill change it there are still so many things to do... @Hellboy787 of...
no big update but it was a lot of work :dremel: now the logo is glued, sanded and polished this is the best i could do, only with a hand saw......
@elctroJunky that would be awesome ;) @Big SturL :D :D
