When I emailed silverstone about this very question a year ago (as I wanted the side vent but not the handle), they replied that it is removable....
That's insane how close they look. I'll take another look at mine but I swear it felt like I was going to break it.
Currently I have 1 SSD and 1 HD in the very bottom, but I will probably add another drive and SSD later. I've never seen the PS07, I tried to...
Hey everyone, I just put an Asus Maximus V Gene into a Silverstone TJ08-E. The USB 3 header location, and the height of the front panel USB 3...
I totally forgot about sound channels. Its typical that I'll start up a game, then connect my headset, and never change the sound settings. So...
I have a logitech g35 USB headset, which I love. I have Logitech's newest software installed, and use it for Skype, mumble, and for WoW and Diablo...
It doesn't have the 6-pin power built in. I know I have a few of those dual molex to 6-pin pci-e power adapters though. That said, all of the...
It's been a while since I bought any new hardware and I'm a bit out of the loop. My wife's shuttle (she uses it for WoW and minecraft, not much),...
I'd agree with DOA to infinity. I've personally had new drives fail within 12 hours of first use, to the other extreme of hard drive in my closet...
I bit the bullet and bought one. Played a few games of SC2 with it, and it is at least as sensitive as my old wired trackman wheel, if not better....
I've used the Logitech TrackMan Wheel (thumb ball) for 12 years or so. In the last 4 years I've gone through 4 of them, with the buttons stopping...
Well, I ended up putting Win 7, WoW, and SC2 on one SSD, and Steam on the other SSD with all its installs. Seems to be working fine. Thanks...
Ha! Good to know that TRIM doesn't work on RAID. I wasn't really going for the normal performance benefit of a stripe anyway, I more wanted to two...
Hmmm. Wait for payday and go buy a new motherboard with raid, or geek out for the weekend and see if I can make it work. My job is actually data...
I've had 1 SSD for a while as a gaming drive, and picked up another one recently. My original intent was to raid the two together (stripe), make...
It would be interesting to see an off the shelf SSD in a MacBook Pro. Drive Genius does some sort of performance testing though I've never looked...
The short answer is that an adapter doesn't exist. The long answer: Rev.A uses PATA ZIF - adapters are readily available Rev.B uses SATA ZIF...
Well I've searched and googled and researched and I cannot find one. But sometimes there are things members of this forum know about that I can't...
Apple's developer conference has always had snarky comments about Microsoft products. Its a building full of Mac devs and usually the audience...
The fan holder above the pci slots is part of the case. The rear angled one comes with it, the front clear one I bought later and added.
